Results 1 to 8 of 8
    Jan 2016
    Default Peugeot 407 1.6hdi U1208
    need help with egr dpf off without u1208 error
    ivanmihov's Avatar
    Nov 2016
    Europe
    try it
    pass in pm
    Jan 2016
    not work, u1208 always present
    Babos's Avatar
    Mar 2012
    i can to do if you need. write me pm if you need
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    your problem is in bad egr off solution
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  6. The Following User Says Thank You to Ignasvw For This Useful Post:
    niboelectronic (26th February, 2019)
    ivanmihov's Avatar
    Nov 2016
    Europe
    I have done a lot edc16c34 peugeot cars with no problems with this egr solution ( zeroing histeresis maps ) well egr is just closed not completly off,but why is this fault U1208 comming when all egr related faults are deleted ?
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    no, when egr plug is disconnected you get this foult because egr solution is incomplete
  9. The Following User Says Thank You to Ignasvw For This Useful Post:
    ivanmihov (26th February, 2019)
  10. #8
    ivanmihov's Avatar
    Nov 2016
    Europe
    Thanks for this useful information
