Opel Astra G Z16XEP EGR OFF
Results 1 to 9 of 9
    Jan 2013
    Inside ECU
    91
    Default Opel Astra G Z16XEP EGR OFF
    Please help with an egr off for Astra G z16xep. i replaced the EGR with a new one but the error is still there. I think the problem is in ecu.
  2. The Following User Says Thank You to leotdx For This Useful Post:
    ktome (5th March, 2020)
  3. #2
    Jan 2013
    Inside ECU
    91
    Is there any egr off solution for this type of engine?
    Jan 2013
    Inside ECU
    91
    Can anyone help me? Cant fiind good solution for xep engines.
    pike's Avatar
    Sep 2013
    1,815
    Hi, what DTCs have?
    Jan 2013
    Inside ECU
    91
    Electrical fault. p0400 and another one with high input. The old valve was replaced with new one . The errors are the same. The problem is in ecu. The z16se, z16xe engines i do with tech2 but for xep is not so easy )
    pike's Avatar
    Sep 2013
    1,815
    Arrow Opel Astra G Z16XEP EGR OFF
    Try this file
  8. The Following 3 Users Say Thank You to pike For This Useful Post:
    konq100 (1st March, 2019),ktome (5th March, 2020),leotdx (2nd March, 2019)
  9. #7
    Hungary
    Hi ,
    what tool use for read this ecu ?
    Could you tell me the password for the uploaded file?
  10. #8
    Hungary
    OK, I answer to my own question Probably it could help to somebody...
    -galletto 1260 works properly
    - somebody can share with me the name and the address(location) of the maps.
  11. #9
    Dec 2011
    east Europe
    43
    Default Help EGR off
    Hallo.please some body make EGR off on this file from Asra H z16XEP.thank you.read with KEES.by obd port.
