Bricked Ford ECU?
Results 1 to 14 of 14
    Feb 2019
    Default Bricked Ford ECU?
    Hi all
    Sorry to make my first post a crap one but I bought a KESS v2 kit from ebay and a map file for my ECU, turns out the seller sent me 20,000 map files and stupid me uploaded the wrong one.
    My car is a 2011 Mondeo 2.0 TDCI euro5 with ECU SW Number BG91-14C204-DP
    I uploaded a ford S-MAX SW number BG91-14C204-DF or something like that.
    Fully aware this is my own fault for not reading it correctly before hitting write.
    I have a backup of the original ECU map file but when trying to re-apply it I get 'Cannot read from chassis' and when i try to start the car i get 'ENGINE MALFUNCTION' and it wont even turn over.
    I am unable to find a replacement ECU nearby and am hoping that someone knows a way i can restore the original backup i took.
    Dec 2015
    Italy
    148
    write the ecu on bench whit ori file
    Feb 2019
    I'm not sure how id go about doing that, OBD mapping is all i've done so far.
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    1,224
    Quote Originally Posted by Mylo3k View Post
    Now's the time to learn
    Feb 2019
    Yeah I guessed that much just not seeing much info about it online anywhere, I guess my kess kit isn't the required kit to do it?
    Sent from my SM-G960F using Tapatalk
    racin-snake's Avatar
    Jun 2009
    360
    If ECU still coms with scan tool it could possibly recovered by using ford ids software and then module initialization to add to pats
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    Feb 2019
    Quote Originally Posted by racin-snake View Post
    Is that something I'm likely to get a hold of myself? Obviously dealers are out of the question I can just buy an ECU set for 150 but rather wouldnt obviously.
    Jun 2009
    360
    Probably be better with ecu set as its gonna cost that for a clone ids vcm then learn how to use it plus in code out codes
    but if you know someone with ids it may well be possible . although the used ecu set maybe a better option for you it was only a suggestion
    regards RS
    UK WEST YORKSHIRE
    7
    i can help
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    1,224
    Get ktag and write original file
    Feb 2019
    Quote Originally Posted by teerak2uk View Post
    I did think about that, is it simple to do?
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    1,224
    It's ok but gets easier as you go on plenty of vids on YouTube just don't rush when opening the ECU's
  13. #13
    Feb 2019
    Cool, I'll buy a replacement ECU and then try and fix the other one I guess.
  14. #14
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    1,224
    Get ktag and try and repair the ECU you have or take care to dealer see if they can do ECU update
