Results 1 to 14 of 14
Thread: Kawasaki immo
    Jan 2009
    Earth
    Default Kawasaki immo
    Hy,i need some key logic for a Kawasaki Versys with ecu Denso 21175-0933 with RA86(attached),i want to write two cn2 for it,thanks.
    Jun 2016
    Budapest HUNGARY
    Quote Originally Posted by Dmythross View Post
    Transponder data:
    PG1:FF
    PG2:05
    PG3: (1.Key fileposition in dump 0x364) D9 BF AB 84
    PG3: (2.Key fileposition in dump 0x368) D9 B2 E2 84
    PG4: (Cryptokey) 4B 48 49 43 50
    If immo blocked the dump file pair and unpair bytes swap
    PG3: (1.Key fileposition in dump 0x364) BF D9 84 AB
    PG3: (2.Key fileposition in dump 0x368) B2 D9 84 E2
  3. The Following 8 Users Say Thank You to f2f2 For This Useful Post:
    acid1983 (29th May, 2021), bangreno (10th March, 2019), Dmythross (4th March, 2019), gecibogar (7th May, 2019), Geekey (2nd February, 2022), Krittanu (3rd March, 2022), mikajna (25th May, 2021), rokibar (25th May, 2024)
    Jan 2009
    Earth
    Correct data,bike ok thank you.
    HeXeN's Avatar
    Mar 2015
    VVDI2 do not recognize version 21175-0933, is possible to make transponder from file with logic? Kawasaki KLZ 1000 2016
  6. #5
    Jun 2016
    Budapest HUNGARY
    Quote Originally Posted by HeXeN View Post
    Send the eeprom bin file
  7. The Following User Says Thank You to f2f2 For This Useful Post:
  8. #6
    HeXeN's Avatar
    Mar 2015
    Hi, here is the file
  9. #7
    HeXeN's Avatar
    Mar 2015
    Please help
  10. #8
    Jun 2016
    Budapest HUNGARY
    Transponder data:
    PG1:FF
    PG2:05
    PG3: (1.Key fileposition in dump 0x364) DB A0 5D 84
    PG3: (2.Key fileposition in dump 0x368) DB 9F 2F 84
    PG3: (1.Key fileposition in dump 0x364) A0 DB 84 5D
    PG3: (2.Key fileposition in dump 0x368) 9F DB 84 2F
  11. The Following 3 Users Say Thank You to f2f2 For This Useful Post:
    gecibogar (7th May, 2019), HeXeN (10th April, 2019), mikajna (25th May, 2021)
  12. #9
    mikajna's Avatar
    Mar 2015
    Quote Originally Posted by f2f2 View Post
    Transponder data:
    PG1:FF
    PG2:05
    Hi friend, can you help me with key data from dump, want to make key already programmed, because motorcycle is not in my garage, only ecu
    VVDI2 not support this version even if say that is supported, Autel im508 recognize it very well but xp200 seems not working with 4D transponders, cant recognize any 4D transponder
    Only tools which successfully prepared transponders are EFFI with ZB, and FVDI but dont know if they work good
    Thanks in advance
  13. The Following User Says Thank You to mikajna For This Useful Post:
    PierreTheron (25th May, 2021)
  14. #10
    PierreTheron's Avatar
    Aug 2009
    Centurion,South Africa
    what happened here ???
  15. The Following User Says Thank You to PierreTheron For This Useful Post:
  16. #11
    mikajna's Avatar
    Mar 2015
    Quote Originally Posted by PierreTheron View Post
    Its solved firend, @f2f2 was not in workshop but help me over whatsapp
    Thanks again @f2f2
  17. #12
    May 2024
    Hi, is it possible to know the eeprom location on 21175-0933 ? Thanks
  18. #13
    HeXeN's Avatar
    Mar 2015
    try this
    zed-full module 238
    https://www.istanbulanahtar.com/en/z...-applications/
    click on the second picture, back of the module
  19. #14
    May 2024
    This is my eeprom file. Can you give me the Key data?
    Thaks
