Hy,i need some key logic for a Kawasaki Versys with ecu Denso 21175-0933 with RA86(attached),i want to write two cn2 for it,thanks.
Transponder data:
PG1:FF
PG2:05
PG3: (1.Key fileposition in dump 0x364) D9 BF AB 84
PG3: (2.Key fileposition in dump 0x368) D9 B2 E2 84
PG4: (Cryptokey) 4B 48 49 43 50
If immo blocked the dump file pair and unpair bytes swap
PG3: (1.Key fileposition in dump 0x364) BF D9 84 AB
PG3: (2.Key fileposition in dump 0x368) B2 D9 84 E2
Correct data,bike ok thank you.
VVDI2 do not recognize version 21175-0933, is possible to make transponder from file with logic? Kawasaki KLZ 1000 2016
mikajna (25th May, 2021)
Hi, here is the file
Transponder data:
PG1:FF
PG2:05
PG3: (1.Key fileposition in dump 0x364) DB A0 5D 84
PG3: (2.Key fileposition in dump 0x368) DB 9F 2F 84
PG3: (1.Key fileposition in dump 0x364) A0 DB 84 5D
PG3: (2.Key fileposition in dump 0x368) 9F DB 84 2F
Hi friend, can you help me with key data from dump, want to make key already programmed, because motorcycle is not in my garage, only ecu
VVDI2 not support this version even if say that is supported, Autel im508 recognize it very well but xp200 seems not working with 4D transponders, cant recognize any 4D transponder
Only tools which successfully prepared transponders are EFFI with ZB, and FVDI but dont know if they work good
Thanks in advance
PierreTheron (25th May, 2021)
what happened here ???
Hi, is it possible to know the eeprom location on 21175-0933 ? Thanks
try this
zed-full module 238
https://www.istanbulanahtar.com/en/z...-applications/
click on the second picture, back of the module
This is my eeprom file. Can you give me the Key data?
Thaks
