Your XPROG is the worst quality. If you want it to work properly, you must restore it to the original. Then the highest version is 5.5.5. If you want a newer one, then you must legalize it on the ELDB website.
Hello. About month ago I've purchased xprog v5.74 clone from aliexpress. On first try everything was ok. But today I've tried to read MCU HC(S)12 on volvo dashboard and I've noticed smoke smell from xprog, like something burned down. And. After this my xprog is working only from external power supply. From USB it is not enough. Before everything was ok. Where should I start? Thanks in advance and sorry for bad English.
P.S red indicator in the middle was lighting before with USB too, now as you see, only when I plug external power in. Without external power not works.
Without external power supply I've got VCC Pin overloaded and sometimes device is silent.
Dewagg (5th March, 2019)
Im not familiar with your piggy back version Xprog but you may start checking the DC-DC converter.
