Results 1 to 8 of 8
    Default Mondeo MK3 airbag reset DIY?
    Hi everyone,
    Is there any way to reset Mondeo MK3 airbag light? I have replaced airbags, pretensioners and sensor. I also have airbag module, but found it written somewhere that it needs replacing only after 4th airbags deployment. And even if I replace airbag module, it still needs programming, doesn`t it? I have ODBII interface cable but as far as I know it can only read data and clear trouble codes.
    Thanks!
    Quote Originally Posted by coss View Post
    Hi everyone,
    Thanks!
    you need a abs airbag resetter or a code reader with the airbag reset on it. if you live near southampton i could do it for you
    RUSSIA Kaluga
    Hi everyone,
    Thanks!
    You have crash data stored in SRS unit! You must clear it!
    I do it by desolderig the chip from SRS unit and reprogramming.
    And what happens if I replace SRS module with the one that was never crashed? Will it still need programming?
    localhost
    Clear out the crahs and then use ids to clear the fault code.
    Quote Originally Posted by djtomcat View Post
    No idea what are you talikng about(crahs, ids). Call me stupid, but I am just looking for a simple answer: will I need programming done if I replace SRS module with the one that was never crashed?
    Meat-Head's Avatar
    IDS is the ford diagnostic system. Under your circumstances, phone the stealer, and ask how much to 'erase a fault code', when you have picked yourself up off the floor, call a few local garage or bodyshops, and ask if anybody can clear crash data.
    If not, put tape over the bulb!
    Isn`t crash data stored in the SRS module? I will be replacing it.
