... carprog...read old...swap...write...done.
With my caddy (my2009) I would like to swap the speedometer for another used one.
Which tool is suitable for reading the original speedometer and programming the other one?
Read for days in different forums and come to no result ..... Can someone help me here, please?
Thank you for the effort.
Greetings tuono
Gesendet von meinem POCOPHONE F1 mit Tapatalk
VVDI can do it too
Read immo data, write immo data , start car
Hi, thanks for the replies....
With Vcds is probably nothing, to read the access pin I had thought the vag eeprom programmer?
Regards tuono
write what is the reason for the exchange. original number of one and the other counter
Good Morning,
my caddy has a speedometer without mfd and I would like to retrofit with mfd.
I do not have the part numbers at hand, I submit.
regards
Tuono
so. in the meters in Caddy without MFD, the CDC ... processor is unprotected and you can read ImmoData, SecurityBlock without any problem. but counters from MFD are secured before reading and each CDC .... is protected against reading ImmoData, SecurityBlock - in case you do not have a programmed key for the meter. (even AVDI org. does not do these counters). to read and save ImmoData, Sec.Block to this counter, the counter must first be unlocked. I use Dragon J-Tag programmer - you have to undo the counter, properly connect the Micronas CDC ..... on the table, read the secret code (the so-called S-Key), after this unlocking procedure and you have full access to the meter data
Hello, Thanks for the detailed answer, I think that exceeds my ability and I will not do it
regards
Tuono
Buy ado dash with mfd before 06/2006 and read e2 from yours and new one. Which tools you have?
