Hey. Can there be a driver X Prog for Windows 8.1x 64?
Hi xoubajato. Im back time have same problem (device is silent ),but with this firmware ,my device now is OK. program firmware ,and exactly fuses and lockbits. try download software for google . Im not upload software here because is very big for upload here.
You can try change v5.5.1. firmware and software. Work OK .
5.5.5 and 5.5.1 firmwares upload for my is tested OK for My.
Reflash eprom and flash file. Program correct fuse bits and bitlock. work OK. Read and Verify correct file data after program. And verify USB wire.
PaoloDigital (20th March, 2019)
wi problem try
need reprogram and 93c46 neighbor FTDI chip.this is for identification same xprog box.
Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
PaoloDigital (21st March, 2019)
problemaicic
Hi. Im only reprog Flash file and Eprom file from ATMEGA 64. And work OK. Full authorizations OK. Sorry. im not have more info.
not working
Hi friend. Im disamble my Xprog Box ONLY FOR YOU !!!! Read you 93LC46B in 16 bit mode and save before change this file !!!!!! No PASS !!! FREEE !!! GOOD LUCK !!!!
ebbie01 (2nd February, 2024), martinracing (27th June, 2020), PaoloDigital (21st March, 2019), Ray6K (27th September, 2022)
not work fike
Im download the v5.5.5 without dongle from download area in this site. Work fine !!!
https://www.digital-kaos.co.uk/forum...&id=34&page=20
killian2008 (24th June, 2019), rch11 (22nd March, 2019), Talleresmalaga (18th December, 2019)
Im unsolder 93LC46B for read in 16 bit mode. But this eprom is not your problem. Verify correct data flash ,internal eprom and fuses for ATMEGA64 after programmig. You can download Xprog v5.5.5 software from download area in this site. REmember . ALL DATA UPLOAD FOR MY IS FOR XPROG WITHOUT DONGLE USB KEY. Other very important detail. Configure hour and correct day in you operative system for problem with certificate. Verify correct port from OPTIONS/ENVIROMENTS/PORTS. And use a good USB wire.
Software v 5.5.5 here https://www.digital-kaos.co.uk/forum...&id=34&page=20
martinracing (27th June, 2020), PaoloDigital (22nd March, 2019)
Thanks , for All, but fike
