Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 45
  1. #16
    sergei5005's Avatar
    Nov 2012
    Bs As
    Hi xoubajato. Im back time have same problem (device is silent ),but with this firmware ,my device now is OK. program firmware ,and exactly fuses and lockbits. try download software for google . Im not upload software here because is very big for upload here.
    You can try change v5.5.1. firmware and software. Work OK .
    5.5.5 and 5.5.1 firmwares upload for my is tested OK for My.
  2. #17
    Junior Member Nevidimka's Avatar
    Feb 2019
    Belarus
    Hey. Can there be a driver X Prog for Windows 8.1x 64?
  3. #18
    Mar 2016
    Quote Originally Posted by sergei5005 View Post
    Hi friend. Im try download the back file and open OK. Now try reupload here. Software AVR for Atmel programmer is include in this file (butnot tested for my. Im use UPA programmer for this.)
    Heelo friend , thanks, after wrire memory , you have , read a MCU for inizializzate? type Motorola?, conncect software , but no work , comunication error, your work after rewrite ?thankls
  4. #19
    sergei5005's Avatar
    Nov 2012
    Bs As
    Reflash eprom and flash file. Program correct fuse bits and bitlock. work OK. Read and Verify correct file data after program. And verify USB wire.
  5. The Following User Says Thank You to sergei5005 For This Useful Post:
    PaoloDigital (20th March, 2019)
  6. #20
    Mar 2016
    wi problem try
  7. #21
    electronistul21's Avatar
    Nov 2011
    galati,romania
    need reprogram and 93c46 neighbor FTDI chip.this is for identification same xprog box.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  8. The Following User Says Thank You to electronistul21 For This Useful Post:
    PaoloDigital (21st March, 2019)
  9. #22
    Mar 2016
    problemaicic
  10. #23
    sergei5005's Avatar
    Nov 2012
    Bs As
    Hi. Im only reprog Flash file and Eprom file from ATMEGA 64. And work OK. Full authorizations OK. Sorry. im not have more info.
  11. The Following User Says Thank You to sergei5005 For This Useful Post:
  12. #24
    Mar 2016
    not working
  13. #25
    sergei5005's Avatar
    Nov 2012
    Bs As
    Default Your 93LC46B original file !!
    Hi friend. Im disamble my Xprog Box ONLY FOR YOU !!!! Read you 93LC46B in 16 bit mode and save before change this file !!!!!! No PASS !!! FREEE !!! GOOD LUCK !!!!
  14. The Following 4 Users Say Thank You to sergei5005 For This Useful Post:
    ebbie01 (2nd February, 2024), martinracing (27th June, 2020), PaoloDigital (21st March, 2019), Ray6K (27th September, 2022)
  15. #26
    Mar 2016
    not work fike
  16. #27
    Jan 2018
    PL
    Hello
    Can you send a link to programs that work well?
    TX
  17. #28
    sergei5005's Avatar
    Nov 2012
    Bs As
    Im download the v5.5.5 without dongle from download area in this site. Work fine !!!
    https://www.digital-kaos.co.uk/forum...&id=34&page=20
  18. The Following 3 Users Say Thank You to sergei5005 For This Useful Post:
    killian2008 (24th June, 2019), rch11 (22nd March, 2019), Talleresmalaga (18th December, 2019)
  19. #29
    sergei5005's Avatar
    Nov 2012
    Bs As
    Im unsolder 93LC46B for read in 16 bit mode. But this eprom is not your problem. Verify correct data flash ,internal eprom and fuses for ATMEGA64 after programmig. You can download Xprog v5.5.5 software from download area in this site. REmember . ALL DATA UPLOAD FOR MY IS FOR XPROG WITHOUT DONGLE USB KEY. Other very important detail. Configure hour and correct day in you operative system for problem with certificate. Verify correct port from OPTIONS/ENVIROMENTS/PORTS. And use a good USB wire.
    Software v 5.5.5 here https://www.digital-kaos.co.uk/forum...&id=34&page=20
  20. The Following 2 Users Say Thank You to sergei5005 For This Useful Post:
    martinracing (27th June, 2020), PaoloDigital (22nd March, 2019)
  21. #30
    Mar 2016
    Thanks , for All, but fike
