If its a slightly narrower blade with a thinner longer internal cut like the one in the picture, I think its a HU162
hi all, bentley continental GT with KESSY system
it seems to have more than 8 cuts, (more cuts than normal HU66, a longer cut line on the blade)
there are no bentley cards to help on instacode to help with decode, does anyone know anything about this HU66 blade?
sdnatlst (5th March, 2019)
No its 9 cuts hu66
Verzonden vanaf mijn iPhone met Tapatalk
thanks all, yes i found out also it is HU66 EXT, meaning 1 last cut on the end
I think all kessy have EXT cut
My first was an a62008 akl.
Key worked in the door but not ignition.i didn't knew about EXT!
Another guy came,he cut the blade but he was unable to program key.
After I've seen his key cutted I understood why mine didn't worked.
Finally I programmed the key.. hahaha
2 locksmith,same car 1key..!
He came from 100km away.
Also you will find many Audi with original key cutted like EXT but normal one will work the same.
Just done a4 2005,TT 2007 and a3 2006.all had EXT cutting but normal one worked as well..
sdnatlst (6th March, 2019)
You're right, only cars with electronic ignition actually need that extra cut (ex. Audi A6 C6, Bentley Continental, Porsche Cayenne, VW Touareg).
And how to make this extra cut? The extra cut is a 2,3 or 4? How to read if lishi only have till 8 cuts?
TukoSalamanca2 (22nd March, 2019)
Here...
https://youtu.be/geFXyC5F1uE
Sent from my MI MAX 3 using Tapatalk
You read 8 cuts with lishi.
Choose ext cut ,intput the bits and cut.
All ext cuts are the same.
Without ext cut key will work on door lock but not in the ignition..
lately ive seen lots of HU83 citroen with EXT cut too, (long cut at end)
however, i never cut it, and still works in igniton and doors,, so thats a strange one!
hu66 definitly does need the EXT for igniton though your right
