The problem is still not resolved. I need help turning off torque monitoring in my file.
Hello, I have a problem with DTC errors regarding the conversion of torque by ECU. Auto is after the remap of my automa. Car goes ok, until I enter the emergency mode. The errors that appear are P1D38-00 and P061B-00, read out by the DELPHI Tester . The car is a Lancia Voyager 2.8 CRDI from 2013 on EDC17CP27. Is anyone able to help me with this matter? Thanks in advance! Files in the attachment.
This is no tuning, this is playing a file without knowledge.
Write this,,,
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
frzn545 (17th August, 2021), krokodyl30 (9th March, 2019), mark72 (4th February, 2020)
Thank you for your honesty, I will test and report the results of your work! Thank you for your help!
Your file is O.K, errors regarding torque monitoring do not appear. Dynamo showed 192 HP and 428 Nm.Thank you!
Thank you for you help
Thanks man!!!
hi, please can i have pw for your file...
