Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    peko's Avatar
    Quote Originally Posted by gad3n View Post
    front connectors 3 chinese amp max .. and this is not good power supply at all ... put oscilloscope and you will see
    not use this
    use conectore behind
  2. #17
    peko's Avatar
    Quote Originally Posted by hcwc View Post
    Are you sure it is sdi6 not sdi6.1 ?
    Had one panamera with sdi 6.1, autotuner fail, ktag fail, cmd fail, kess only id so i gave up on that one
    yes 6.1
    is same as 6
  3. #18
    Sep 2014
    Any news ?
  4. #19
    peko's Avatar
    Solved 😜
    wires have trouble
    i replace it and all solved
    support from alien is not good ,Dora king about alim
  5. #20
    Dec 2015
    I'm having the same problem with a Panamera SDI6.1 ECU.
    I can get ID by a few flashers but none of them can unlock or read it.
    May you please tell me what you finally did?
  6. #21
    peko's Avatar
    not forget to join 2 pin on PCB and after all is ok to R/W
  7. #22
    Jun 2020
    Have you solved that problem
