Page 1 of 2 12 LastLast
Results 1 to 15 of 23
    DK Veteran sroka's Avatar
    Oct 2010
    Poland
    Default Vectra C Z19DTH Swirl Flaps Remove
    Hello!
    Hardware manufacturer number: 0281014450
    Software Number: 1037502505P485
    Could you help me removing this 2 DTCs:
    P2075 - Swirl Level Sensor Circuit Open or High Voltage
    (05) - Present
    P0660 - Swirl Level Control Solenoid Valve Circuit Open
    (04) - Present
    read kess v2
    regards!
    Feb 2019
    EU
    Default swirl off
    jest dtc swirl off
    Oct 2010
    Poland
    bebor is stiil the same foult codes
    stanislav georgiev's Avatar
    Oct 2014
    България
    Try again with my decision
  5. The Following 3 Users Say Thank You to stanislav georgiev For This Useful Post:
    badisan (3rd May, 2019), KestasU (7th November, 2021), sroka (12th March, 2019)
  6. #5
    Oct 2010
    Poland
    stanislav work perfect big thx
  7. The Following User Says Thank You to sroka For This Useful Post:
    stanislav georgiev (12th March, 2019)
  8. #6
    DK Veteran badisan's Avatar
    Dec 2009
    Hello,
    I tried to remove FLAPS OFF with a swiftec program but without success.Please help.
    Vectra c Z19DTH Swiril Flaps Remove P1110 P2075 P0660 P1109
    Bosch Hardware Number: 1037A50284
    Bosch Software Number: 0281012534
    Opel Software Number: 5519715
    Best regards
  9. #7
    moky's Avatar
    Apr 2010
    Behind you
    Hi all
    someone can Swirl Flaps Remove this opel Z19 DTH please?
    I have dtc P2075-61/62 and 63 to remove
    many thanks !
  10. #8
    Oct 2019
    Need need need please ....LOL
  11. #9
    moky's Avatar
    Apr 2010
    Behind you
    Quote Originally Posted by Anonimius View Post
    ?? good intervention my friend thanks....
  12. #10
    mancioks's Avatar
    Feb 2017
    Germany
    Quote Originally Posted by moky View Post
    Hi all
    many thanks !
    but this file is not original, i see that somebody already try to delete swirl here
    If i helped, don't forget push thanks + rep
  13. The Following User Says Thank You to mancioks For This Useful Post:
    moky (15th November, 2019)
  14. #11
    moky's Avatar
    Apr 2010
    Behind you
    Quote Originally Posted by mancioks View Post
    sorry but it's file I read..will search original file on base thanks
  15. #12
    moky's Avatar
    Apr 2010
    Behind you
    just found original file on my base and file is 100% original mancioks..
  16. #13
    Oct 2014
    България
    Read full bdm to remove the flaps
  17. The Following User Says Thank You to stanislav georgiev For This Useful Post:
    moky (16th November, 2019)
  18. #14
    Oct 2014
    България
    Here is my decision, but it should be written BDM
  19. The Following 2 Users Say Thank You to stanislav georgiev For This Useful Post:
    mancioks (16th November, 2019), moky (16th November, 2019)
  20. #15
    Sep 2012
    Prague
    HI,
    can you please help me with swirl flaps off ?
    DTCs P2075 and P0660
    Vectra C Z19DTH
    0281014450 1037390674 HNOMS240
    Thanks a lot
