Megane III 1.5 dCi SID305 ORI File
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    172
    Default Megane III 1.5 dCi SID305 ORI File
    Hi ..
    search ori file
    Sid305 Megane 2011
    Continental S180067144A 237101495
    HW0669R
    SW 1495R
    ThK
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
    Jul 2012
    5
    send the reading of your file to rebuild original or to compare
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    172
    ok ..
    see file ...
    this file is modified, auto has mil ON, no dtc error in ECU, no recovery.
    I need file ori to understand error!
    ThK
  4. The Following User Says Thank You to centrohifi For This Useful Post:
    chafik4051 (7th March, 2019)
    Dec 2018
    77
    not precisely as it is necessary, but has to help
  6. The Following User Says Thank You to Catalizator For This Useful Post:
    centrohifi (8th March, 2019)
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    172
    your file is OK ...
    but I changed the key code, in address 0001C00 ed coding Igniction
    Car Start
  8. #6
    Dec 2018
    77
    Fine. Now errors are visible diagnostics?
