Flash module ODIS and it should work
hi there dear members. could any member please advice on what could be done to fix powersteering on b8 audi 2013 model. powersteering does not work. very hard. many thanks for any advice. keep well,
Friday,08,March,2019,10:19:56:16946
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: WAUZZZ8K4DA084716 License Plate:
Address 44: Steering Assist Labels: 8K0-909-144.clb
Control Module Part Number: 8K0 909 144 F HW: 8K0 909 144 B
Component and/or Version: RCEPS H36 0507
Software Coding: 100000000001
Work Shop Code: WSC 08490 001 1048576
ASAM Dataset: EV_RCEPSAU48X 008014 (AU48)
ROD: EV_RCEPSAU48X_008.rod
VCID: 34677AE69F795DE645-8060
1 Fault Found:
6291727 - Internal Control Module Memory Check Sum Error
B2000 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Mileage: 122616 km
Date: 2018.08.20
Time: 00:01:38
valid
frikki (9th March, 2019)
Hi there. Could you please explain a little deeper into Odis dear friend. I have red on dk. I do have vas pc. Software 17. Is it possible to get Odis software to work with head. Thank you. Keep well.☺
yes vas 5054a cable with odis service and odis engineering ... use the second one to flash modules
frikki (10th March, 2019)
Thanks. Where can I find Odis software dear friend. Thanks
for me it came with it's software as i remember but was german ... so i downloaded it but the two softwares and odis service will be yellow icon and odis engineering will be blue icon and download flash data which will allow you to change part number for software
Hello i have the same on audi Q5 steering 8R0 909 144F and flash does not help. Does anybody have eeprom dump from good unit?
Noboda have the eeprom dump? Pls
