adblue off sid310
Results 1 to 8 of 8
    branco's Avatar
    paris france
    38
    Downloads
    260
    Uploads
    Default adblue off sid310
    hello all friends
    need to disable adblue for renault master 3
    ecu siemens sid 310
    need 100% working solutions
    I have 4 files modified by swiftec but none work
    any info welcome
    file attached
    May 2018
    Downloads
    Uploads
    i know only one person who do this job with success
    i tryed many solution but no one have the solution
    branco's Avatar
    paris france
    38
    Downloads
    260
    Uploads
    ok thanks
    can you give me contact please?
    many thanks
    May 2018
    Downloads
    Uploads
    check your inbox
    Dec 2013
    27
    Downloads
    27
    Uploads
    This ecu is very hard to be done scr(adblue) off.
    DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
    branco's Avatar
    paris france
    38
    Downloads
    260
    Uploads
    Quote Originally Posted by gitko View Post
    hi
    pass protected
    need pass
    regards
    Jul 2016
    114
    Downloads
    Uploads
    hi i have same problem pls i would like to disable adblue on a navara sid310 ecu could u pls help me thankms
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    181
    Downloads
    Uploads
    Voltehcar have solution, me too
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  9. The Following User Says Thank You to Ignasvw For This Useful Post:
    amrilyes (19th September, 2019)
