if the egr valve is faulty, and not closing properly the "EGR off" wont help, because you need to blank it mechanically. So If you suspect, that valve isn't closing properly first you should blank it, and check if the boost value is in specified range.
Also, DTC off won't help, because you will still go to limp mode, but without error code in the fault memory. With this kind of errors (boost, fuel pressure) it's better to fix them
This kind of fault is not registered without a reason...
Did you check the vacuum hoses to the turbo's? Is the vnt fully pulled when car is started on idle and the boost dc is on max side?
