Results 1 to 12 of 12
    Dec 2018
    Latvia
    Default Audi A6 ELV Swap problem
    Hi guys, hav some problem of ELV swap for Audi, i have used ELV from car, the MCU is with 4MB eeprom, and original is with 2MB eeprom, is possible to swap those our no number are little be different on ELV cases, and mask of MCU are different, can some one give some info about that, i will add a eeprom dumps
    Nov 2018
    Poland PL
    because there were two types of processors in ELV - ... DG128 and ... DG256. read both ELVs, backups and upload content from 128 to 256. I have done more than once.
    upload content from 128 to 256 - address 0800-0FFF.
    file in ... DG256 is always empty until the first half
    these EZS 4mb, were mounted on the A6 C6 Lift 2009-2011 models
    Dec 2018
    Latvia
    Quote Originally Posted by yarowsc View Post
    You mean copy past data i right area?
    Dec 2018
    Latvia
    After made modifications with this dump ELV, start to burn at most ELV Motor start to burn. and car don't see this immo data, after this modifications need only change eeprom data, our swap also flash?
    Nov 2018
    Poland PL
    upload these 2MB to 4MB address 0000-07FF (the first half of the file). second half do the whole FF.
    now it should be OK.
    Dec 2018
    Latvia
    But my original file for 4KB was first have FF and after adress 0x800-0xFF0 was data, and i swapped data from 2kb to 4kb like in original, but when i put back to car, Motor inside ELV Start to burn, and really lot, i disconet motor, but still ELV don't see the key, you are shore that now i need to add data to first of file from 0000-07FF??
    Nov 2018
    Poland PL
    try. I assembled ELV ..DG256, from the place ELV ..DG128. it definitely works
    Dec 2018
    Latvia
    But why my motor start to burn on used ELV?
    Dec 2018
    Latvia
    and some on old original ELV, something is bad in dump. i'm think so!
    Dec 2018
    Latvia
    Don’t work this method! Our I have bad used elv!
  11. #11
    Nov 2018
    Poland PL
    well. therefore write what is the reason for the replacement of ELV? What happened to replace ELV?
  12. #12
    Dec 2018
    Latvia
    problem was not turning ignition on, problem solved with another ELV with 2kb MCU, tomorrow will make a assembly and car go to client!
