Can you write the codes...the picture is so scruffy.
U2107-71
B3902
C044A-08
C0000-08
U2105-00
P2101-00
B3925-00
Codes listing
Once running need to stop it happening again, possible alternator screwed
on the first post you said "The car originally died while driving"
what you try to do now sounds crazy with reprogramming of whole car modules over and over .
if I look again over your first post it's pretty clear your engine ecu could be damaged of some wirings around him
( P xxxx codes and C xxxx codes )
Someone else worked on the car after it died. When I got it, it was a mess and none of the computers shared the security key. The IPC also had a different key. This is why I had to reset everything.
These two codes:
B3925 and B3902
Which module gave them....BCM???
Yes it did
What about IPC.
Is there any codes?
If I remember correctly the IPC also complained about the BCM. The ECU and SDM did not have any issues.
Try to reset BCM and reprogram it once more.
Any chance to get tech2 or mdi somewhere?
Over the last 2 days I have tried all combinations and I cannot get it to work. I think there is either a wiring issue or the BCM is faulty. I have tested the CAN bus extensively and all is well. Termination is 60 ohm and the oscilloscope shows good solid wave forms
If u have disconnected BCM:s connectors several times take a look at there is no bending pins out there.
nope there are none.
