Page 4 of 4 FirstFirst 1234
Results 46 to 54 of 54
  1. #46
    Feb 2019
    The fuel pressure is correct, 3.5 bar. What else can I check?
  2. #47
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    I have read the whole thread but by your last sayings ignition is ok(spark is good)
    And you say injectrors work well too.
    If you have these two and car still wont start then i think only timing is left...
    You have fuel injected by the injectors?Or just fuel comes to the rail?
    IF you crank and car wont start,check rpm of engine to see if crankshaft sensor is working well...
  3. #48
    kiszka's Avatar
    Quote Originally Posted by gerriecpt View Post
    Replace the spark plug and ignition coil
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  4. #49
    Feb 2019
    Opcom shows the rpm when cranking so it is to the crank sensor. I did replace the plugs. I tested the injectors on the rail but removed from the cylinder head so that I can see the spray pattern.
    I doubt it is timing since than will cause blowback through the intake or to the exhaust.
  5. The Following User Says Thank You to gerriecpt For This Useful Post:
    Stelaras26 (16th April, 2019)
  6. #50
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    haha its like magic.You have both fuel and spark but its a non starter!
    Pretty strange.
    Injectors may spray but car wont start if they spray wrong.
  7. #51
    Feb 2019
    I got it to start with quick start and let it idle till it reached running temperature. Switched it of and started it a few times successfully.
    After standing through the night it wont start again unless you use quickstart again. It is very strange
  8. #52
    Feb 2019
    As an update to this. I have discovered that the issue is around a cold start. I need to spray quick start in to get it running when cold. Once hot, the car will start over and over on its own. It is almost as if it is to lean when doing a cold start
  9. #53
    Shmortz's Avatar
    in the middle of nowhere
    try to replace fuel, maybe there is diesel on it or fuel is bad.
  10. #54
    kiszka's Avatar
    Quote Originally Posted by kiszka View Post
    check if it's gasoline for sure
    if you would do what is said to you
    this topic would not have more than 4 pages
    you ignored me
    We think what to fix, you earn
    look for another job This is not for you
    I wonder if I will see magic buttons pressed
    in return
    Our knowledge does not fall like manna from heaven
    You will start to go for training and you will see how much it costs
    Reality of life :
    3:Everyone lies
  11. The Following 2 Users Say Thank You to kiszka For This Useful Post:
    brend (17th April, 2019), rafal (17th April, 2019)
