Can someone help me?
I don't understand your question, what you need?
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
The 1600 TDI injectors are noisy. The noise can be eliminated by making a modification on the PCR2.1file
Has anyone had this problem?
That happened to me, in a car from the vw diesel gate update.I put a previous file and it was quite quiet.
Can you attach the two files to understand where to act to avoid the beat?
you right but i don't know the solution
If someone wants to share an opinion, they are welcome
You need to have a tool that R/W a FRF file in order to update (upgrade or downgrade), sw alias.
And if you need a file i might have it, but ill check your file SW version when i get home mate.
You need to downgrade software version before 9970 and make injectors adaptation.
You have an example?
