1600 TDI VAG Injectors solution
Results 1 to 13 of 13
    TuningInside83's Avatar
    Dec 2016
    Italy
    48
    Default 1600 TDI Injectors solution
    anyone know how to solve the problem of noisy injectors on VAG 1.6 TDI CR?
    I attach original file PCR 2.1
    Thanks in advance
    Dec 2016
    Italy
    48
    Can someone help me?
    DK Veteran sdtsedat's Avatar
    Jan 2015
    Belgium
    202
    I don't understand your question, what you need?
    ​Original Kess V2 + CMD + Autotuner + Winols + ECM geniune owner
    With Kind Regards,
    Don't forget hit thank button if i helped.
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2
    Diesel + petrol
    Belgium
    Dec 2016
    Italy
    48
    The 1600 TDI injectors are noisy. The noise can be eliminated by making a modification on the PCR2.1file
    Dec 2016
    Italy
    48
    Has anyone had this problem?
    Oct 2013
    Spain
    34
    That happened to me, in a car from the vw diesel gate update.I put a previous file and it was quite quiet.
    Dec 2016
    Italy
    48
    Can you attach the two files to understand where to act to avoid the beat?
    Sep 2010
    21
    you right but i don't know the solution
    Dec 2016
    Italy
    48
    If someone wants to share an opinion, they are welcome
    Aug 2018
    Portugal
    15
    Default Need to have tool that can write FRF File
    You need to have a tool that R/W a FRF file in order to update (upgrade or downgrade), sw alias.
    And if you need a file i might have it, but ill check your file SW version when i get home mate.
    Mar 2016
    You need to downgrade software version before 9970 and make injectors adaptation.
    Dec 2016
    Italy
    48
    You have an example?
  13. #13
    vagva's Avatar
    Apr 2016
    116
    Quote Originally Posted by TuningInside83 View Post
    WHAT IS YOUR NAME RELATED TO : TuningInside83
    ARE YOU REALLY A TUNER OR BLBLBLBLB NAME ?
