Results 1 to 15 of 17
    AvechuchoAxel's Avatar
    Downey, CALIFORNIA
    Default 2012 ROLLS ROYCE GHOST INSTRUMENT CLUSTER EEPROM LOCATION / CONNECTION
    Hello mates..
    Does anyone have back connection and / or eeprom location for this R.R GHOST 2012 ?
    CAS4 is already done.
    I don't want to take the risk removing pointers...they look very fragile and hard to remove.
    Thank You
    FxShaw's Avatar
    Nov 2013
    Outta This World
    If I recall correctly then you don't have to take out needles. would of been nice if you at least took a pic of it and upload it!
    even if you have no choice but to take out needle to get to eerpom then i would highly suggest u take out the eeprom and do it direct
    🔥Wacka Wacka 🔥
    Downey, CALIFORNIA
    Here is the board and front.
    Sent from my SM-G965U using Tapatalk
  4. The Following User Says Thank You to AvechuchoAxel For This Useful Post:
    norbisko (7th April, 2019)
    FxShaw's Avatar
    Nov 2013
    Outta This World
    seems like you took out a smaller board at the back? no eeprom on that one?
    🔥Wacka Wacka 🔥
    Downey, CALIFORNIA
    I dont recognize the IC mask....
  7. The Following User Says Thank You to AvechuchoAxel For This Useful Post:
  8. #6
    Downey, CALIFORNIA
    It's a DC-DC conv
  9. #7
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Cant see what it says on it...but try reading it as 35080/95160 and see what u get. if not needle off I guess.
    I know 95160/35160 on the the small board 2013+ but I dunno location on older ones.
    🔥Wacka Wacka 🔥
  10. #8
    Downey, CALIFORNIA
    A5973D EB045
    A5973D. Up to 2 A step-down switching regulator for automotive applications
  11. #9
    Jan 2016
    its 35080 , have to remove needles, 2013 is 160dowq on small board
  12. #10
    Downey, CALIFORNIA
    It's scary to remove needles.... I do many cars... but I have never done one of this.
    Any tip or advise??
  13. #11
    batandball's Avatar
    May 2011
    Push down on needles, small pressure and twist against the stops
    If it works use it
    BatandBall
  14. #12
    Downey, CALIFORNIA
    Thank you.....Job done already pulling out needles...
  15. #13
    Aug 2018
    Hello.... by chance can you tell me location of CAS Module... is its CAS4 or FEM for this vehicle... if CAS4..it under steering column on left side? .. is it easy to get too?
    thanks!!
  16. #14
    Downey, CALIFORNIA
    Quote Originally Posted by ammreid View Post
    thanks!!
    CAS4 is located just next to the lower steering column, right side. Its a WHITE BOX
  17. #15
    Moderator
    PremierD's Avatar
    Jun 2009
    Correct ........................
