Results 1 to 14 of 14
    Top Poster + denis1hr's Avatar
    Jun 2009
    near you....
    Default Need Modus steering electronic dump
    I need the virgin dump of ECM of steering electronic.
    Here is the photo with numbers.
    I also need this dump. Have you got it yet?
    I also thought to get virgin uch dump then try reprog uch to new column. So do it the other way round.
    I have similar problem. I need virgin dump for steering ecu or someone who know how to edit VIN and other things in dump.
    I edit only vin number but after that UCH don't recognize steering module, is there any checksum ??
    I need to put vin : VF1JP0F0532793150
    to dump bellow.
    Quote Originally Posted by rapi View Post
    to dump bellow.
    what eeprom is inside?
    what I remember it is 24c16
    does anybody know how to do it ??
    I ended up replacing the steering column, lock with remote, uch and ecu from a clio 3.
    One of the problems is that new ones are now slightly different and a virgin dump from the latest replacement is totaly different.
    didi_du_93000's Avatar
    France Paris
    Quote Originally Posted by albertros View Post
    Hello Albertros,
    Have you got this virgin dump of your new steering please?
    Oct 2011
    hi,
    I need Modus Power Steering Reprogrammig Tool.rar
    tanks'
    Ashraf6119's Avatar
    UK
    Quote Originally Posted by valentinmarc27 View Post
    hi,
    tanks'
    Do a bit of research here and i am sure you will find this tool here as, it was posted by Patrian which works with Renault Clip..........
    Edited............There you go mate................
    http://www.digital-kaos.co.uk/forums...-fault-163551/
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Quote Originally Posted by didi_du_93000 View Post
    Hello Albertros,
    only just spotted the request!
    I replaced the units with used ones so there was no dump from a new column.
    I also missunderstood the breaker who sold me the parts, they infact came from a modus not a Clio3. If you fit a Clio set onto the modus the dash is different so more problems, although it starts.
    The virgin dump on this site only works with some columns, its trial and error.
    peko's Avatar
    hi friends
    you need clip tool because you virgin steering colone, so after you must recode it with clip ???
  13. #13
    HI,
    new column recodes itself.
    You have to set up steering angles thats it.
  14. #14
    Mar 2012
    Please help repair. Modus column.
