just write the eep in an identical bsi and it will work
I write to another BSI but the car did not start. The two BSIs are not exactly the same, they are different revisions. Is this the problem or I need to write and flash
boot is Valeo with MC912
the bsi sw and hw must be the same
try to write the flash too, maybe it will work
r_parev (15th March, 2019)
Ok, thanks
You should check your bsi dump if there is vin and pin. If the dump is damaged, you will not start the car even with the new bsi with the same sw and hw. The best solution is to virgin bsi and configure with pps/lexia, you will need pin, you can find it in your bsi dump
(if it is good), or in engine ecu.
r_parev (16th March, 2019)
post your dump here. If is ok read pin code and vin. In new(used) bsi put FF for all adress in eeprom (hc12) and reprogram with PP2000 like a new bsi.
its 10 minute job
Please check my dump, maybe damaged.
Unfortunately, your dump is corrupt (that's why it did not start the car)
in your case:
1. you need to get pin code from the ecu eeprom
2. put a virgin dump in your bsi
3. program your bsi with pp2000 (see txt file)
gieteknysa (18th March, 2019), r_parev (17th March, 2019)
can i replace my bсi with this one?
This is my:
This is new:
Please need pin code.
Peugeot 307
ECU Bosch EDC15C2 eeprom 95P08.
pin code: JL6M
r_parev (20th March, 2019)
