Results 1 to 15 of 17
    Paris, France
    Default How to open BSI on Xsara 2001 HDI
    I have a Citroen Xsara 2001 HDI 2.0, with the BSI unit dead, I've found a second hand one and I want to put a virgin file in.
    So how can I open the BSI unit and where is located the eeprom which need to be reprogrammed?
    Best Regards
    Paris, France
    If somedy know?
    Here are pics of my BSI, how can access to the eeprom needed to be programmed with a virgin file?
    Thanks!
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by lobalt View Post
    If somedy know?
    Thanks!
    Unless you want to do a lot of Desoldering (which is the correct way )..Turn the BSI up the other way ... and I'll Mark where you cut it with a Dremil... (Cowboy I hear you say )......
    I Just remembered ...It might be an nec....mmmmmm need other photo....
    dashradio's Avatar
    Inafield
    Hi, looking at your 2nd picture have a look about 2ins from bottom right hand corner for the 8 leg chip, is it a 95040?
    Where is the BSI on a 2001 Citroen Xsara Picasso. What does it look like. My rear wiper got iced to the window and will no longer do a pause wipe, it will only do a four sweep cycle and stops anywhere but the park position. How do I reset this.
    DK Veteran Xram's Avatar
    Glasgow
    Quote Originally Posted by PremierD View Post
    Not sure on the others but the Valeo unit doesn't need cut if you use a screwdriver down each side of the multiplugs itll easily pop open no need for cut though I think the other units need cut.
    drpeter's Avatar
    The Netherlands
    It is a NEC, so no eprom. desolder the pins on the right side (middle picture), unclip connectors and turn the right side of the board. Its very small, you need glasses for this BSI :-)
    PS Remove the board with the yellow, blue pink and black connector. Had one saturday, give me a headache.
    Moderator
    PremierD's Avatar
    Jun 2009
    Like this small mate ..
    BTW ...it does open .. without desoldering ....
    Best Regards
    HELLO
    Look your eprom
    becarefull it is sticked!!
    drpeter's Avatar
    The Netherlands
    OK I could not next time I try thanks :-)
    Yes this is the right board on the other side.
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by geniehex View Post
    HELLO
    Look your eprom
    You are correct mate .... did not look close enough at the pickies ... ( this will be the easier of the two then ...)
    drpeter's Avatar
    The Netherlands
    I never saw a Picasso 2001 VALEO BSI with 95040?
    After 2004 is SIEMENS BSI with 95040.
  13. #13
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by drpeter View Post
    Straight Xsara...mate ... Not picasso...Done a few ...
  14. #14
    drpeter's Avatar
    The Netherlands
    aha, looks exactly like Picasso, didn't notice it sorry.
  15. #15
    DK Veteran sl4ck's Avatar
    lobalt, could you please post virgin dump to this BSI?
