Results 1 to 9 of 9
    Mar 2019
    Madrid
    Default Problem ECU Scirocco 2.0 TDi EDC17CP14
    I have read the maps of this ECU (EDC17CP14) with FG Tech 4 by the OBD.
    When I was writing the new maps I got an error, So I dismantled the ECU and i tried to boot it but when it was at 3% the following error appeared: ERR FILE 014400 - OTP SECTOR NOT WRITABLE
    I can read the current eeprom and internal flash, but i canīt write the internal flash.
    i have tried to write with kess V2 (Boot mode) too but without result.
    I havenīt got the original EEPROM file, i just have the int Flash original file and the EEPROM that i could read with Galleto after the error.
    I need to write this ECU, right now It's just an ugly paperweight.
    Thanks in advance!!
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    WVWZZZ13ZAV... is the VIN of this ECU... It seems that itīs 2010... 100% it has TPROT... chceck it...
    Try to flash it with ODIS/ODIS-E with Ori SGO...
    When I help you press Thanks and Reputation...
  3. The Following User Says Thank You to figani For This Useful Post:
    sparkecu (24th March, 2019)
    Feb 2013
    hi!
    try to write it with ktag by bdm
    good luck
    Mar 2019
    For this solution you need to write FRF file with ODIS E
    figani's Avatar
    Feb 2018
    Quote Originally Posted by sparkecu View Post
    yes, you can try it with VAS/Odis but also with VCP...
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    i think he try in bootmode write partial file. .. Its your car given you killed?
    My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
    My help not for free, press THANKS and REP, for make me HAPPY
    im not using passwords, my work is for this forum and members free
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    OTP one time programing.
    In ecu are are these location in mpc (for immo-no ecu swap--- but today its gone)
    If you want to car start, put original read by obd back by obd.
    in this ecu is Tprot (tuning protection)
    Mar 2019
    Madrid
    Solved with ODIS, thank you for your help guys.
  10. #9
    Jan 2024
    Quote Originally Posted by Danimp94 View Post
    After using ODIS, could you write with OBD or did you still have to go boot mode?
    Similar issue on my end where I've got Tprot and trying to boot but I damaged the contacts for the resistors and don't want to risk it by connecting directly onto pins on the board.
