Results 1 to 3 of 3
Thread: ABS delete
    Jun 2018
    Default ABS delete
    Hi guys. I have to delete the ABS in my Lupo 3L because it is converted to manual and ABS is not working. It used to be controlled by the gearbox ECU, which is now not needed any more. So, I will be ditching the ABS module, and will obviously have to deal with the ABS light on the dash, a handbrake warning and a code stored after the conversion. Is there a way to "sign out" ABS using VCDS and be free of errors? Or do I have to go to a tuner AGAIN to have it mapped out? Cheers
    Sent from my iPhone using Tapatalk Pro
    Mar 2019
    Quote Originally Posted by iwcham1979 View Post
    I'm trying to pass my lupo in box at 100% manual speed. did you find a program / MAP that turns your lupo properly?
    (because with a 1.4TDI original ECU, our lupo 3l does not roll well, unless it is modified)
    If yes, can you send me the MAP?
    I am currently working on ABS too, if someone in the forum has a shema of every component of the ECU (ECU engine, ECU ABS, ECU gearbox) so that I can see how I can modify our lupo for us to go Functional ABS.
    I think that the ECU of the gearbox sends a signal to the ABS ECU, for example "it's good, the clutch / the brake pedal is activated, you can operate the ABS"
    But for that, I need an electrical diagram of each component, if you have not hesitated to share me in MP.
    If my changes work, I will share with as many people as possible so that we can all enjoy.
    Jun 2018
    Default ABS delete
    Hi. I bought the map for 50euros, the guy sent it to me by email in a rar file.... Then I had it remapped to 80hp and flashed to my ecu by a tuner... I have lost it unfortunately... I could have the tuner extract my remapped file but it would cost us both... I spent 50euros for the original map plus 100 for a remap plus 30 for a flash plus 20 for immo off... so total of 200euros just for that... I would happily share my remap for 100euros... (It would probably cost me 20-30euros to have it extracted first) If somebody is interested, I will see what I can do if you decide to unleash the beast Here is my run...
