here is fixed.. but write vin ,keys manualy . try read by xprog to campare both eeproms
here is eeprom and flash i read on a cas3 module i picked up from the local yard. just curious to check if VVDI prog is reading correctly. i did make a key via bench and works, but i checked eeprom on cas3+ editor and shows errors, but is this because that program only for cas3+ and this cas is just cas3? thank you for any help.
cniksor (17th March, 2019)
Are you sure that module is cas3?
Maybe cas2?
What is the mask on motorola you read, 2K79X ?
VIN: WBANE53527CY04690
KM: 237215 km
Key cutting code:HA00016741
CAS remote control frequency:315Mhz
Sorry DG550 u have right! in cas edit i have info - cas2 - vin -WBANE53527CY04690 isn - B9 F0 . It isn't cas3+ eeprom
yes cas3 taken from a 2006 e60 , OL01Y. not customers vehicle. but when i see a cas modules at the local yards i like to grab and read to keep files handy/share as im learning more and like to on spare parts. this one i read like i normally do, but since this is cas3 and not + i was curious is cas3+ editor is accurate or is only for cas3+ specifically.
i made key with cgdi bench, and tested it on my bench setup with cluster and it turns on fine like i normally check my keys. so just wanted a 2nd opinion is it is correct, just curious if reading correctly on vvdi
