    Jun 2014
    Default what kind transponder done to copy by key tool
    Hi, did any one know what kind transponder i must use to copy by (vvdi key tool) ?, i use transponder megamos 48 but error, i load 3 photos, 1 by tango to let you know what kind transponder i use, and the 2 others from key tool, please can any one help me to have the right info?.
    1- can i use this function to copy transponder by vvdi key tool for vw 2007 ?
    2- or this function 96 bit just for newer vw up 2013 ?
    thank you in advance...
    Apr 2016
    uk
    Quote Originally Posted by pouleddy View Post
    Is possible to clone id48 on be till 2013.
    Your id48 non locked is ok to use it for clone.
    You need to choose id48 96bit copy online,sniff 5 times, upload data and than write new transponder..
    Have you used id48 96 online clone?
  3. The Following User Says Thank You to comizelu For This Useful Post:
    pouleddy (17th March, 2019)
    Jun 2014
    some one he tell me there is special transponder for copy by vvdi key tool, i can't copy by vvdi key tool simple transponder id48 it not ready to done, so how i can check if my transponder with 96 bit??? is there any tool can show my transponder with 96 bit?.
    Apr 2016
    uk
    The transponder you showed on tango is good.
    You don't need any special transponder for key tool.for other tools like keyline or silca,yes you need their transponders but not for key tool.
    There are plenty videos on YouTube for cloning id48 with key tool.just watch and do the same.
    I usually program these but I also done a few clones using normal id48.
  6. The Following User Says Thank You to comizelu For This Useful Post:
    Jun 2014
    friend i use transponder which in my first post show by tango, but don't done. it show also massage in my first post by key tool (write failed not support this chip). so i don't know where is my mistake.
  8. #6
    Nov 2015
    Transponder looks ok. Maybe try use new app for xhorse tools.
