    Jul 2017
    Default 308 2014 not open the doors after changer the mileage
    Peugeot 308 2014
    cambia el kilometraje y ahora no abre las puertas con control.
    por favor ayuda...
    sony_2006's Avatar
    algeria
    1: With your key. You put yourself on the + after contact (2 notches).
    2: Then in the 10sec, you press for 10sec minimum on the button of closing of your key (big button).
    3: After this time. You remove your key and wait 30 seconds without touching anything or any button.
    4: try! It should work
    Jul 2017
    [QUOTE = sony_2006; 3528977] 1: Con tu llave. Te pones en el + después del contacto (2 muescas).
    2: Luego, en los 10 segundos, presiona por un mínimo de 10 segundos en el botón de cierre de la tecla (botón grande).
    3: Después de este tiempo. Quita la llave y espera 30 segundos sin tocar nada ni ningún botón.
    4: prueba! Debería funcionar [/ QUOTE]
    it is with smart key
    what do you mean by the key in +
    thank for you help
    sony_2006's Avatar
    algeria
    Here the way
    Jul 2017
    help............control does not open the doors..........
    sony_2006's Avatar
    algeria
    Page 57
    Failure - reset
    from the remote control
    After disconnecting the battery,
    a change of the battery or in case of
    malfunction of the remote control, you
    can not open, close, and locate your
    vehicle.
    Place the mechanical key (integrated in the
    remote control) in the lock, to open
    your vehicle.
    Remove the carpet under the 12 V socket
    F Remove the dongle in the
    housing provided for this purpose.
    Switch on the ignition by pressing "START
    STOP".
