Here you go.
Here you go.
PSAcars (20th March, 2019)
Hello badziewo sorry for late answer but today tested car. No diag to airbag ecu. Light is on.
Hello to all. If someone can help?
Compare with previous solution, it should work ok ...
Best regards.
Dragon
Hello to all. Dragon thank you. You have more cleard lines in file. But the start of file is the same. Will try and post result.
Hello to all. Dragon100 thank you. Now I have connectio tonecu, but I have error that where not there in first plase. When car came had only curtain deployment. Now with new curtian I have this errors. Car is US 2012 if it matters. The pasanger seat is there and it is ok ( last error )
Hello to all. Any help please?
Check, pass the same ...
Best regards.
Dragon
PSAcars (23rd March, 2019)
Hello to all. Thank you Dragon100.
My file work ok now ?
Best regards.
Dragon
Hello to all. Yes dragon your file is 100% good.
can someone clear this file also,
2012 HONDA RIDGELINE SRS
