Test and report.
Test and report.
mkopytekchi89 (19th March, 2019)
Will report back in 2 days. Thanks for the help@!
With this clear i am getting B1416 and B1418 which come up as internal module fault, Internal EEprom fault. Prior to fixing the seatbelts and installing airbags i only had side collision and frontal collision. So i know the module did not have these codes before. I will try to program it again and see what happens. Do you know if this is a tested solution?
Try and report the result
i will be working on the car again tomorrow and will report back. Thank You.
here you go 100%,in case you still need it,pass in pm
mkopytekchi89 (22nd March, 2019)
Here, 100% clear.
Clean up your inbox
Thank you everyone for the help. I was getting fault codes b1416 front left impact sensor and b1418 front right impact sensor. My Infiniti qx60 only has one front impact sensor. It appears the clear files everyone was sending me were correct just module tey use had 2 impact sensors. I clear my original file from line 910 to df0. i program 95128 and did not have to clear any codes. light turned off by itself. i scanned the airbag module and it is operating properly without any faults. I upload my clear working file. PM for password. Cheers!
Hello, mkopytekchi89 can I have the password for your fixed file please.
Clear Infiniti File
dmka (19th January, 2020)
