Other question.. Can i Reprogramming without remove eeprom? (with clip?)
i need to remove screen on my board (for the access 93c66)
How to disconect the screen?
Thanks very much and i'm sorry to my english
yes can program in circuit, I cut the lcd legs with side cutters then solder back together. It is quite hard to solder off lcd, I have done that too...
jomberykaso (19th March, 2019)
Use the search function, you will find backside connections.
giustyle (19th March, 2019)
I found it:
i need to connect also pin 8 or not?
Thnks
Yes you need Pin 8.
Thanks but I try and don't work
This is problem, I use tl866cs
Could be your programmer or the connections to the programmer.
With a good device/programmer you can read/write this one without any problems.
The model of EEPROM Is correct? ATC?
Thanks for the help
It has a S93C66
If i helped you with your problem, please press the Thanks button.
Ask your questions in the forum, no response on private messages.
But I don't found in the this list:
What is the manufactoty?
hi
st 93c66
giustyle (20th March, 2019)
Thanks, now the programmer is "work" but..
How I lower voltage?
