File Name: corsacbcmdump.bin
Unit: Body Control Module
EEPROM: 93c66 EEPROM
Vehicle:
Security Code:UNKNOWN
Part Number:24410827
Ident:CY
Vehicle:
Ident:CY
Thank you for your time, i'm assuming it's a corrupt dump if there's no security code in it?
I removed it from the PCB and read multiple times and verified the read data is stable?
The reason I’m doing this is because when I attempt to program the remote on the vehicle it says incorrect access code, but the customer does not remember the BCM being changed since they’ve had it.
Suppose the only option is to Virginise the BCM and they code back to the car
Try to read from IPC
Update** If anyone was wondering.
Wrote a virgin file back to the BCM, then coded back into the vehicle with the original pincode for the car.
Then programmed as many remotes as i needed.
bonecrusher (7th April, 2019)
but you can share us the virgin file dont you
Anyone could help with PIN code extracting from attached dump?
A topic that interests me
pin code - 1015
Correct is 1510
Fuller (16th December, 2020)
IMG_20230905_101419.jpgIMG_20230905_101419.jpghello pls help with corsa c bcm pin code
Have you tried with OpCom clone?
As far as I can remember there was an option for pincode reading on a Corsa C…
