Hi.It is easy job to open dash and remove eprom.just remove dislay and U will find eeprom.
Can anyone tell me is it possible to do direct with eeprom dash on Mercedes G-Class 2014-2015?
Dash looks like this one:
https://di-uploads-pod3.dealerinspir...-016-GOI-D.jpg
If it is can someone share location of the Eeprom chip and how to get there ?
Thanks In advance
yugo45 (21st March, 2019)
No , its just in between the dials under the screen..
Ok I found it , it is very easy , Thanks for that.
Eeprom is 95640.
Can someone calculate Km for me , Original 19065km , I need 25250km. (Yes I need to go up about 6000km)
Also does anyone know can I test to see Km on table , I see in diagram Pin 1 is Ground , Pin 4 is 12V but not see how to light up LCD?
Thanks In advance .
Try the file if it is correct Thanks +Reputation
yugo45 (23rd March, 2019)
Anyone knows how to light up LCD on table , it is possible at all?
Just want to make sure what Km display.
probably needs can to wake up it would be easier to just plug in into car to check
Please hit thanks if this helped you!
sony_2006 file has 25.216 kms on it.
03 14 to DEC = 788
788*32 = 25.216 kms
Change 0314 to 0315
Good Luck!
