Hello dear,
yes the dump is correct, try to program new key then test it if is still the same problem so EIS must be replaced
Hello dear,
Hi. Same problem. Central locking is ok but key dont want turn. In actual values i see that start message is not received from transmitter key. Key data are beeng entered - NO. Energy supply for transmitter key - NO.
Please check dumps from EZS out CPU and KEY.
Read MCU2. These dumps are ok. Thanks.
alexbeshko (30th March, 2019)
Thanks. So it means that dumps look ok. If I take new EIS from scrapyard I can load this dumps and all must be ok? Or need renew ESL and ECU?
Надіслано від мого SM-J500H, використовуючи Tapatalk
I will read mcu2 and post here. Maybe possible to repared?
This is a dump from cpu inside
Please check if all is ok with this dump. Thanks.
<---- Coin of the Realm.
I did nothing with esl and not yet try swap it.
I will read esl data and post them. Thank You for help.
