Try this. I hawe im my dump collecion immo off. Mybe it works in urs car.
I have a HYUNDAI ATOS 39110-02743 and all solutions I have try until now, including carlab files, nothing of them works.
All files dosnt start the fuel relay pump and if I make it +GND and start it forced, the engine start but working abnormal, keep high rpm and when it goes high temp it ends.
All files with forced +GND start the engine and after that noone of them works normal.
Is there anyone that has a tested solution and no test files, to finish it please cause I gonna crazy please?
I attach all immo off bad files for 39110-27043 I have test.
Thank you in advance
If I help You. please say THANKS.
Amir15 (21st March, 2019)
It doesnt work my friend,
Anyone else please can help??
regards
You have a problem with your ecu my friend
That was my first thinking and now I have 2 ecus with same symptoms. Also while I search on forums etc I found that the symptoms I have are often in these type of ecus if the sw version is not correct.
Google it and you will understand.
Any help please???
regards
Here is atos 1.0 tested by me...
Use new 27c512 or UV eraser
Pass is :
5+=12
+=19
+=24
Donabe (9th March, 2020), georgedigital (29th September, 2021), halupka (6th November, 2020), karageorgos (22nd February, 2021), lounadak (7th March, 2022), Mitsakos (30th September, 2021)
hello all does this files worked ??
an paizei steile moy ena mynhma...
