Awesome if you have to, small micro switch on a spring on throttle pedal to cut input to ecu when got gas on
alfons37 (25th March, 2019)
On brake pedal should be 2 switches, one turns on back brakes light and the other inform ecu you pressed brake pedal, simply disconnect wires from this second switch and you have homemade left foot braking with no gas cut.
Yes but some ecu has input from brake light input to flag had switch
leave switch hanging fit another, pick up look in footwell, cut wire done
I have try this, if i disconnect all 4 wires (remove contact), working when i do this but not have brake light.
I have test cut cable bot work, i think only is editor software in ecu
Anyone?
I pay of course for working solution
You cut wrong cable. There are two independent switches, find the one that turn lights on and disconnect the other.
morgano (26th March, 2019)
Sorry i test file but not work
alfons37 (26th March, 2019)
Also the abs has input brake brake lights
Thanks work good last file many thanks mate
Meat-Head (28th March, 2019)
