Results 1 to 3 of 3
    Oct 2018
    Default Mercedes a140 p0600
    hello dearest members
    i have a mercedes a140 1.4 gasoline siemens MAF ecu msm 1.3 with error P0600 Can bus com in ecu
    -immo has no errors
    -key turns, starter does not spin
    -using fvdi i went to Adaptation, Reset coding. now car starts perfect but fan is always spinning and i get P0602 Module programming error.
    -Probably missing flash info, if i flash a new ori file maybe it will work but it will change immo info as well,,
    any solutions to this? is immo off possible?
    really appreciate any input
    WinWoj's Avatar
    Jan 2012
    ECU City
    No immo off for this. Universal emulator can do this, but I think you repair immo sync, when you used fvdi. So your problem could eventually solve star diagnosis, or something another. P0600 I'm not sure is about flash. I think such coding data in eeprom is not good. Look more carefully there. Cheers.
    Oct 2018
    if i do virgin in flash can i resynch with fvdi?
