Try this file
Try this file
My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
My help not for free, press THANKS and REP, for make me HAPPY
im not using passwords, my work is for this forum and members free
Do I need to disconnect immo box?
unfortunately Your solution does not work (immo box was disconnected).
Can somebody help with immo off?
my file from here: https://www.digital-kaos.co.uk/forum...-0-261-201-208
What is problem- car cranking or no cranking?
kobi2311 (26th March, 2019)
car is not cranking
I can help you.
Write this
I will try it tommorow and will report. Immo box must be disconnected all the time?
You can disconnect immobox and put jamper between 9 and 18 pins (k-line ECU and OBDII diag connector).
If it is not writed eeprom 95080, pay attention to Status Register
Lada Niva immo
HI
Problem solved. The car is starting now. I have used file with name "B120ER.16" from (user) Pyromaniak link.
The second problem was with car's wiring too. After I have repaired car's wiring and loaded immo off file - car started.
Thank for all who was trying to help with this issue.
Pyromaniak (26th March, 2019)
