Results 1 to 8 of 8
    Jul 2013
    Latvia
    Default Checksumm for MB W211 Delphi DCM 3.2
    Hi guys!
    Can someone please correct checksumm for this file?
    Car is MB W211 E220
    ECU is Delphi DCM 3.2
    Thanks in advance!
    sdtsedat's Avatar
    Jan 2015
    Belgium
    No need to fix crc.
    Just make a map and putt all files in that map.
    Delete ori .MPC and replace it with the tuned/edited MPC file.
    Write FULL backup and K-Tag calculate crc.
    Good luck!
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
    Jul 2013
    Latvia
    I can write file, but after writing I get DTC about checksumm error.
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Quote Originally Posted by flashtech View Post
    You not listen what i write.
    Just do what i say
    Sedat Garip
    Belgium
    With Kind Regards,
    kire106ka's Avatar
    Aug 2012
    MACEDONIA
    galletto makes cks
    IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
    Jun 2014
    Do you have SW number? I believe that I have OBD and MPC versions. Greeting
    Jul 2013
    Latvia
    Maybe someone can help?
    Still can't correct cs, car is not starting..
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    Here you are
    My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
    My help not for free, press THANKS and REP, for make me HAPPY
    im not using passwords, my work is for this forum and members free
  9. The Following User Says Thank You to Pyromaniak For This Useful Post:
    flashtech (25th March, 2019)
