if car starts and runs good but you have "remaining starts" on a dash you need to change coding of dash.
can someone help me to remove Adblue warning about possibles engine starts (Remaining starts: 0). I think this car already tryed to do Adblue off, but not to the end correct solution.
Car has not engine faults, engine starts and drives good.
Thanks in advance!
It is not necessary online access to reset it, it is necessary only right solution
DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
Nothing happening when unplug module.
