Results 1 to 14 of 14
    Sep 2014
    Somewhere
    Default Opel Vivaro 2.5 DPF off needed
    Hi to all!
    Please help with DPF off on a OPEL VIVARO, year 2006, engine 2.5 diesel
    ECU type EDC16C36 0281013363
    HW: 8200635663
    SW: 1037383334
    Thanks!
    WinWoj's Avatar
    Jan 2012
    ECU City
    Try this and report. No pass. Chk ok.
  3. The Following User Says Thank You to WinWoj For This Useful Post:
    Jashmine1983 (25th March, 2019)
    Sep 2014
    Somewhere
    Quote Originally Posted by WinWoj View Post
    You did it by DPF Remover 2017.05?
    Is tested on other cars?
    WinWoj's Avatar
    Jan 2012
    ECU City
    Quote Originally Posted by Jashmine1983 View Post
    Not tested. Did as you said. Have to check and reflash, when didn't work mate.
    Sep 2014
    Somewhere
    Solution is not OK...already tested it.
    Still need a good solution for DPF OFF....hope somebody will help with other file.
    Thanks!
  7. The Following User Says Thank You to Jashmine1983 For This Useful Post:
    WinWoj (25th March, 2019)
  8. #6
    Sep 2014
    Somewhere
    Anybody can help with a good DPF off solution on this Opel Vivaro, please?
  9. #7
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Here working 100%
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  10. The Following User Says Thank You to Ignasvw For This Useful Post:
    Jashmine1983 (26th March, 2019)
  11. #8
    Sep 2014
    Somewhere
    Quote Originally Posted by Ignasvw View Post
    Here working 100%
    DPF light is ON and the car does not go over 2500 RPM. What might be the problem?
  12. #9
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Perform reset before write. i never had problems with same solution
  13. The Following User Says Thank You to Ignasvw For This Useful Post:
    Jashmine1983 (29th March, 2019)
  14. #10
    Sep 2014
    Somewhere
    Can be reseted with OPCOM?
  15. #11
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Yes you can use opcom
  16. The Following User Says Thank You to Ignasvw For This Useful Post:
    Jashmine1983 (31st March, 2019)
  17. #12
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    always reset dpf before flash mod file and file from ignasvw should work
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  18. The Following User Says Thank You to AVDigitale For This Useful Post:
  19. #13
    Clear dtc from modules and DPF lamp wi'll go off.
    Sent from my S90_Apex using Tapatalk
  20. The Following User Says Thank You to alladdin205 For This Useful Post:
  21. #14
    Sep 2014
    Somewhere
    OPCOM doesn't have DPF reset on Vivaro.....the DPF light disapeared after deleting DTC in ECU.
    Thanks to all!
