china carprog it will not worke
you need orginal
Hello everyone,
i have been trying to reset the Airbag module on my 2010 mustang.
i purchased a Carprog from china with the latest and gratest software and addapters.
Now i have found out that it doesnt do anything besides looking like the original.
The module part# ar33-14b321-af (infeneon). i only purchased the tool for this module only, however it is turning into a much more than i anticipated.
i connected the A1 to modified c1 connector. I connected the powe,ground and the toe can wires with 500ohm resistor between them.
it attempts to communicate with the ecu, then i get (ECU not Responding)
can it be used, modified.
Thank you in advance
you need orginal
If I helped please press rep + thanx
Nino2019 (27th March, 2019)
