Results 1 to 4 of 4
Hybrid View
    Mar 2016
    Sweden
    Default problem dpf off vw 2.0tdi ppd2.1
    hi,help correctly remove dpf disconnect sensor in vw passat b6 2.0tdi 170hp ecu siemens ppd2.1
    DPF REMOWER no working thanks your
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    if you have diff sensor problem, there is no solution that will help. Change sensor or remove dpf lamp
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    Mar 2016
    Sweden
    Quote Originally Posted by Ignasvw View Post
    there is no solution at all vw ppd2.1 dpf off,I ask for help
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    You didnt understand me. Solution on theese ecus is not full. all is working ,no regenerations but if differential sensor get foult, dpf lamp start to blink
