Need bsi flash for citroen jumpy 2008 VF7XT9HUC
MOTOR 9HU
VIN:VF7XT9HUC64217874
BSI 966405878001
BSI04EV K01-00 080708
THANKS
MOTOR 9HU
BSI 966405878001
THANKS
give us signature of flash
You save backup before pin reading....check your log it is something wrong learn key 18
Bsi live or not try read FLS and post dump or try chage mileage smok write mileage Fast new flash from files folder
Software index 0501
Try to read flash but all was FFF
Bsi was dead until I flash another flash,
and elektronic get work but car not starts, starter not running
Try this .....and report .
baubynis (29th March, 2019)
File is wrong size it get error by the trying to write flash with smok
look here ....
A topic that interests me
baubynis (30th March, 2019)
attached flash collection of Johnson Controls
use under your responsibility, Reasons:
Possible change of mileage, most are virgin, need synchronization with ecu, need to re-enter pin and encode all keys, you need manual configuration of vehicle equipment: Example if it has daylight, automatic gearbox, pivoted box, fap, ....
My advice would be to load the flash and code your BSI as a new replacement part
Follow the steps to enter new pin code, (eye has to use the one that brings your vehicle or the keys already codified previously will not work)
once you work immobilizer, enter into
Choose type of gearbox and pivot, by default comes in automatic, record the telecoding,
start a minimum of 3 times and verify that the immobilizer works well,
look for a donor same equipment already telecoded
Exchange eeprom, they will be the best € 40 spent, save a lot of time and headaches
We almost all have, Johnson Controls corpse in the closet ...
regards
If help is useful thanks+rep
Barajasz207 (4th April, 2019), baubynis (30th March, 2019), estrika (12th January, 2024)
Adjusted.....
baubynis (1st April, 2019)
merci beaucoup pour avoir passe du fichier
