Results 1 to 15 of 23
    minimex's Avatar
    Aug 2013
    EU
    Default Scania COO7 repair, dump MPC and eeprom, Basic and Extended
    Hi friend,
    in the attachment is what you need, dumps coordinators
    versions: Basic (061, 800) and Extended (060, 700).
    All files come from unlocked COO7.
    K-Tag programmer (v. 6.070) for MPC5554 (plugin 246) and any for AT25256.
    In the set a description of how to connect a K-Tag from a COO7 pcb.
    Changing balls under MPC is a different procedure,
    you need station for removing and assembly of BGA, stencil, balls, good flux and also manual skills,
    good luck.
    Program "PIN code" for Scania, info via PM.
    >>> If I helped you please press Thanks and Rep. - Password only by PM <<<
  2. The Following 126 Users Say Thank You to minimex For This Useful Post:
    3abas27 (1st April, 2019), achtzz (7th September, 2020), acid1983 (12th June, 2019), Adek2005 (10th January, 2023), Adept aMADeus (6th February, 2020), adriand1281 (15th July, 2021), AGK (19th May, 2022), alessio93 (14th February, 2020), Amauri (28th July, 2022), andrusca (23rd July, 2021), armpower (6th May, 2019), Aung Kyaw Htun (29th March, 2020), autoco (17th March, 2023), autoelek (6th May, 2019), avskpu (14th May, 2019), azerty2019 (20th June, 2020), bearheroes (6th January, 2020), BMW FAN (13th October, 2020), bokilee (18th January, 2020), Borisbro (30th April, 2020), Bugo82 (28th June, 2022), burakk (28th May, 2019), cepi (3rd April, 2019), chicotecni (28th March, 2024), ch_vladimir (16th December, 2020), croco85 (8th April, 2021), Csikker (22nd November, 2020), damian1236 (24th November, 2020), danieldanut (1st November, 2023), dataman (28th June, 2023), dino2010 (13th February, 2020), dist01 (24th March, 2020), djluk (16th April, 2021), dogadan (11th November, 2020), DOUGLASDL (29th March, 2019), drusello (25th September, 2020), DVIZHOK (15th May, 2019), Dzeepromer (26th August, 2021), eeprom241 (14th July, 2022), ekas (25th April, 2019), Elektronix (13th December, 2020), Elvis123 (26th November, 2022), engecu1 (3rd April, 2019), ggabo71 (22nd July, 2020), hugos31 (28th September, 2022), hyperlink (25th June, 2020), INEGMA (13th August, 2020), JamboMan (24th October, 2021), janusz21 (1st April, 2019), jlobo (2nd May, 2021), karlsoncik (25th January, 2021), KARTAGE (16th June, 2020), Khalid052 (18th June, 2021), kikikis2001 (3rd February, 2024), kjbocian (19th September, 2022), kokosz (7th March, 2021), kooper8282 (23rd October, 2022), Labtech24 (24th September, 2020), line44 (1st August, 2022), lobofelix (10th February, 2023), lsalt100 (24th September, 2022), m204 (28th February, 2021), maazouz (8th November, 2019), maher1800 (12th October, 2020), majaree (25th March, 2023), makura (16th June, 2019), maluch12 (26th April, 2023), manisze (21st August, 2019), marekms (25th March, 2021), MarekP (3rd January, 2021), MartiLer (16th October, 2020), mecadriano (28th November, 2020), moddder (10th February, 2020), Moseshamza (14th April, 2022), mounir2011 (31st December, 2021), nabilahmed (16th July, 2021), natcorporation (15th January, 2020), nazaeas (9th October, 2023), neck (13th August, 2019), Nikola1309 (16th September, 2022), normal1 (4th September, 2019), ossun (8th April, 2020), ozibo (2nd January, 2020), ozzzo (9th March, 2023), pauluzs (24th January, 2023), QDtehc (17th February, 2021), qqqmaker1 (3rd March, 2022), ra4yel (18th August, 2019), radiodecoder23 (25th April, 2019), Radouanediag (3rd September, 2023), Redoc (17th April, 2019), ribaria (8th August, 2019), riste (15th June, 2022), robdim (27th May, 2019), ryzen (13th September, 2021), saidvirusss (27th October, 2020), SANTYPALA (20th October, 2020), sanyad30 (3rd September, 2019), saurian55 (27th September, 2019), SheepDog (16th September, 2022), shtyrya2 (28th August, 2019), sisco1 (12th January, 2020), smokinjoe (28th November, 2020), spanaz1 (6th August, 2022), sskorus (19th April, 2019), stevebbb (1st April, 2019), taxo1965 (12th January, 2020), Tereksaz (8th September, 2023), Tkourahara (20th October, 2020), Tsirka (5th January, 2020), tu329 (26th October, 2022), tulio1234 (18th September, 2019), turgutsan (23rd June, 2021), vasiliev7719 (26th April, 2019), vasyaha (19th September, 2019), Vint75 (5th May, 2020), wiseman (10th December, 2021), woytek90 (13th November, 2019), yokazik (9th December, 2022), zar0079 (1st April, 2019), znoki (4th September, 2020)
  3. #2
    minimex's Avatar
    Aug 2013
    EU
    mini manual, COO7_can bus testing
  4. The Following 30 Users Say Thank You to minimex For This Useful Post:
    AGK (19th May, 2022), Andres Alonzo (8th October, 2020), armpower (6th May, 2019), Aung Kyaw Htun (29th March, 2020), Bllinda (23rd June, 2020), bokilee (18th January, 2020), ch_vladimir (17th December, 2020), CLK1201 (31st July, 2022), djluk (16th April, 2021), dodge69 (4th December, 2019), DVIZHOK (15th May, 2019), Elvis123 (26th November, 2022), ggabo71 (22nd July, 2020), hbalazs (6th June, 2019), INEGMA (13th August, 2020), KARTAGE (16th June, 2020), lsalt100 (24th September, 2022), m204 (28th February, 2021), maluch12 (26th April, 2023), nabilahmed (25th January, 2022), ozibo (2nd January, 2020), radiodecoder23 (27th April, 2019), radioman (28th August, 2019), sisco1 (25th June, 2021), taxo1965 (12th January, 2020), thayer201 (15th July, 2020), turgutsan (23rd June, 2021), valdete (6th March, 2020), Vint75 (5th May, 2020)
  5. #3
    minimex's Avatar
    Aug 2013
    EU
    mini manual, COO7_can bus testing by XCOM
    OBD II (interface VCI 3) pin 6 - CAN H, pin 14 - CAN L, pin 4,5 - GND , pin 16 - +24 V
  6. The Following 14 Users Say Thank You to minimex For This Useful Post:
    armpower (6th May, 2019), autoprogarage (21st May, 2019), bokilee (18th January, 2020), Devshore (7th November, 2019), djluk (16th April, 2021), DVIZHOK (15th May, 2019), Elvis123 (26th November, 2022), KARTAGE (18th June, 2020), nabilahmed (16th July, 2021), Oldman35 (3rd June, 2020), pajalnik (24th November, 2020), radiodecoder23 (27th April, 2019), Vint75 (8th May, 2020), woytek90 (27th March, 2020)
  7. #4
    Newbie lwisko58's Avatar
    Aug 2016
    Warszawa
    Thank you for access
  8. The Following 6 Users Say Thank You to lwisko58 For This Useful Post:
    CLK1201 (31st July, 2022), Elvis123 (26th November, 2022), garageozcar (18th August, 2019), ggabo71 (22nd July, 2020), Kochan (5th January, 2020), maazouz (8th November, 2019)
  9. #5
    Mar 2017
    Good job.takes alot of input especially working with ktag on this one
  10. #6
    Dec 2010
    hi ,,,need buy macaca programmer or osjtag
  11. The Following 6 Users Say Thank You to hugos31 For This Useful Post:
    CLK1201 (31st July, 2022), IanBMW (14th October, 2023), maluch12 (26th April, 2023), nabilahmed (22nd January, 2022), TeiS (14th September, 2023), V8Tech (27th July, 2022)
  12. #7
    Oct 2020
    pass please
  13. #8
    Sep 2021
    Quote Originally Posted by minimex View Post
    Hi friend,
    good luck.
    Hello. Can you share the password?
  14. #9
    Nov 2015
    Dear minimex, how to get the password please?
    "thanks" if i helped you is really appreciated
  15. #10
    Feb 2019
    Hi friend,
    good luck.
    Thanks For your help
  16. #11
    Feb 2020
    pass please
  17. #12
    Feb 2019
    Default password
    Hi friend,
    good luck.
    hi,
    could you please assist me with the password for this zip file?
    thanks and reputation given
    thanks again
  18. #13
    Jun 2020
    Default PM??
    What does that mean?
    I'm new here on the forum
    Brazil.
  19. #14
    Sep 2022
    Thanks for your help.
  20. #15
    Feb 2019
    Nederland
