Results 1 to 14 of 14
    Mar 2019
    Default C-MAX EDC16C34 ISSUES
    Hi to everyone,
    new member here, long readouts but still with issues.
    Car initially given to professional for DPF OFF. It works now for some time but 3 flags always one and occasionally limp mode.
    EGR started playing up so I decided to kill the dragon my self armed with a Galletto and WinOls shield.
    EGR deleted, 2 flags disappeared and no only "tank level low" remains.
    The bad thing is car has low boost!?!
    It feels that any boost transferred above 3000rpm. When cold in the morning is even worst, to the point reviing it to 2500 just to leave a junction.
    Everything else is fine, no mils, no flags, no funny sounds, nothing.
    Car Info:
    Ford C-Max 1.6 Tdci 2006
    EDC16C34/2.20/2.
    1037380350 when read, somehow shown 1037396911 when write
    7M51-12A650-UG
    Anyhow, bellow are the files in case someone can assist in the battle,
    Thanks,
    George
    TuningInside83's Avatar
    Dec 2016
    Italy
    Original file?
    Send here
    Mar 2019
    Unfortunately the original lies with the professional who made the dpf off couple years back and the guy closed the place
    The only I have is the DPF OFF file which I took from the car.
    Mar 2019
    Any help or info what further will be highly appreciated
    ohkarol's Avatar
    Oct 2010
    PL/UK
    best way is to flash your car with IDS to update ecu with original file
    if ids not avaliable you need to look for origial file for your galletto.
    contact me later via pm or skype so i will look for ori file in my database
    bFlash/Kess/Ktag/CMD Master
    DPF/EGR/DTC/AdBlue/ChipTuning. ------>PM
  6. The Following User Says Thank You to ohkarol For This Useful Post:
    GeorgeC (3rd April, 2019)
    johak's Avatar
    write this
  8. The Following 3 Users Say Thank You to johak For This Useful Post:
    diags (17th April, 2019), GeorgeC (3rd April, 2019), morgano (3rd April, 2019)
  9. #7
    Feb 2019
    hy,
    here are the original files
    1037380350 and 1037396911
    good luck
  10. The Following User Says Thank You to Peppos3 For This Useful Post:
  11. #8
    Feb 2019
    before writing the modified file, you must perform a fap replacement with a diagnosis and possibly add diesel in the tank where the fap liquid goes
  12. #9
    Dec 2016
    Italy
    your file
    pass pm
    try and report
  13. The Following User Says Thank You to TuningInside83 For This Useful Post:
  14. #10
    Mar 2019
    Thanks for all your help guys, I will try and let you know for the developments
  15. #11
    Mar 2019
    Finally managed to find some time to check the files. Unfortunately none of the above worked, Galleto did not allow me "operation canceled". I found online 1037396911 ori and try to write, Galleto did not allow me "operation canceled", all light and immo started flashing and I thought it was locked. Before giving up I decided as a last try to write an online downloaded 1037380350 bdm ori for focus and it accepted it !
    I tried EGR off and DPF off with winols on this file, write again but car shows both as not deleted .
    Anyway, at least it now starts up and runs .
    Thanks for the above assistance anyhow, if someone has an original 1037380350 for C-Max 1.6 Tdci 2006, EDC16C34/2.20/2. , 7M51-12A650-UG manual will be more than welcome to share
    Bellow are the original and the modified winols if you want to have a look, what i noticed is that when started writing modified, esp light came on but writing completed OK and no issues when car started.
  16. #12
    Talleresmalaga's Avatar
    Nov 2017
    Espaņa
    this is what I have from vehicle to house, I will attach it in case it is worth
    Ver.HW: BOSCH EDC16C34/2.20
    SW act.: 1037399615
    Year: 2006
    engine: D/HHDA-1E PSA
    regards
    If help is useful thanks+rep
  17. The Following User Says Thank You to Talleresmalaga For This Useful Post:
    GeorgeC (10th April, 2019)
  18. #13
    Mar 2019
    him mine is the 1.6 109hp G8DB, i think they are in the same finally, I will keep it as a last resort, thanks!
  19. #14
    Mar 2019
    any further assistance would be highly appreciated guys, still no egr & dpf off. . .
